No throttle response
I have a 2006 Mustang Gt Premium 4.6. The trans was rebuilt and after I got it back after a few hours it has no throttle response. You can put it in gear and it will idle forward or backwards but it won’t take any throttle in any gear, Park, or neutral. I assume it’s in limp mode. Already Changed the gas pedal, and throttle body. Reading two codes for PCM, and 3 codes for o2 sensor. |
What is one of the codes, U0101? That will do it, no communication with the transmission
control module. I had an issue with my former Charger, the TCM would not work when the temperature was below 35 degrees. It would go on gear, then just idle it. No throttle what so ever, it would just give a small surge when on the gas pedal, like to 1000 RPM to 800, and repeat; car wold barely move. You're asking, say you have codes, then don't post them, so we're gonna guess... I'd be calling the transmission shop too... Say, hey, it ran for 2-hours, now it won't move... |
Originally Posted by Llmggraham
(Post 8617543)
Originally Posted by Derf00
(Post 8617607)
Usually including the codes helps to get some relevant replies ;)
