01 mustang gt misfire with no code
Could be air getting in behind the MAF sensor. Any unmetered air that gets
in, can cause rough running, and not throw a misfire code.
You need to get someone in the car, rev it up to 3000 RPM and see if it still
misfires, and look around. If it is an actual misfire, once the RPMs
are up, it would do it.
Also, it can be pulling timing under load, that will not throw a misfire code either.
That's usually bad plugs.
Your misfire will throw a code after so many faults. It took my misfire to show a check engine light after 50 miles. But my OBDII showed a misfire on the third plug on the section listed under pending faults with no check engine light.
Blacksmoke
10-31-2010 09:48 PM
camed281
09-08-2008 11:03 PM
philly3384
03-01-2006 01:42 AM
