2000 Mustang Gt P0308
Old 05-23-2019, 10:48 PM
VenegasGT
VenegasGT's Avatar
Default 2000 Mustang Gt P0308
hello i have a 2000 mustang gt with the 4.6L and i recently got a check engine light that threw the code P0308 (cylinder 8 misfire), i swapped coils from cylinders to see if the code would change and nothing still the same po308 i proceeded to check the spark plug and found that it was covered in what appears to be oil but i could be wrong it might be coolant , i checked the rest of the plugs and the rest where all fine , i was thinking about replacing the valve cover gasket but the gasket is not leaking. now im at a stand still. and there was no oil puddle in the cylinder
Cylinder 8 plug right after i pulled it out
VenegasGT is offline
Old 05-24-2019, 02:26 AM
08'MustangDude
Banned
08'MustangDude's Avatar
To view/manage your attachments, click "Go Advanced"
08'MustangDude is offline
Old 03-19-2020, 04:08 PM
eef_00
eef_00's Avatar
hey, i've got these same symptoms on my 2016 gt. misfire on 8, oil on the plug (or anti-seize? i changed out the plugs a few weeks prior and may have used too much). ..tried a new coil pack, then tried the old spark plug, but the issue persists. just wondering how this all played out for you?
eef_00 is offline
Dathan
10-05-2015 05:52 AM
bconboy
09-21-2015 12:52 PM
1pretzel
07-30-2010 07:01 PM
slynnes
10-19-2007 01:11 PM
ByPopularDemand
05-10-2006 02:14 PM
Quick Reply: 2000 Mustang Gt P0308
