Big power with superchargers...
RE: Big power with superchargers...
ORIGINAL: cekim
Not so much a function of efficiency as it is "where does the heat build up"?
With a twin turbo setup you have 2 red-hot hunks of metal under the hood, full headers ands and something like 6 feet (really rough estimate) of tubing snaking around under the hood...
I was not concerned about the charge temp so much as I am the heat under the hood period... Screws do make lots of heat, but nothing like a turbo turbine...
ORIGINAL: macdaddyslomo
Turbo's make more heat , but they also aren't parasitic on the engine. They are more efficient....usually with an intercooler, underhood heat really isnt a problem. I am assuming you are talking about charge temps. I seriously doubt overheating the engine would really become an issue any more so than a supercharger
good point.
heat on a turbo set up isnt that difficult to handle though. higher capacity radiator, along with heat extractors on the hood would andle that
....however a good turbo setup should be capable of higher peak numbers than a supercharger. When you are talking about 700-900+ hp cars, I dont see some tubing or spending a few hundred more to handle heat being much of a problem
jwog666
12-27-2021 08:09 PM
09-25-2015 06:58 PM
