Got my Bassani X-pipe!!
Wasup fella's I got my xpipe, but there one problem. I orderd the 3-piece one( I couldnt afford the one where you can take out ur cats for straights). The one i got in the mail comes with the x piece, the passnger and driver leg, 2 cats, and 2 other pipes with them. the 2 other pipes look like they go on the pipe instead of the cats?DId the send me the 5 piece instead of the 5 piece or wat, and on the instructions they only sent me one page and not the other. Im gonna install them today, i need feed back plz help, thanx alot guys.
RE: Got my Bassani X-pipe!!
Cyberwolf,
The Bx-series x-pipes come in 3 pcs. The 2 front header pipes should have the cats welded on them. The other pc with be the X- part. The 2 head pipes will bolt on the headers and then slip into the X. You should have some band clamps to tighten these parts together. The rear part of the X bolts right up to the cat back system. I hope this helps you.
P.S. The stainless one is the 5 pc....actually more....the cats also slip joint into place, with the option of putting the off-roed legs in place of the cats.
Casey S.
Casey S.
Thats what i was thinking(that the cats would be welded to the head pipes), but the one i got came with 2 head pipes,2 separate cats, the actual x-pipe, and 2 other pipes(look like they are the cat elimanators). The parts look a little shiny so im thinking it could be the SS ones( i think the 5 piece only come in SS).
