Trouble w/ 3rd gear in '07 GT
Old 09-20-2006, 10:16 PM
jk4music
jk4music's Avatar
Default Trouble w/ 3rd gear in '07 GT
Hey guys,
I got my '07 Gt about a month ago(can't figure out how to post pics). Occasionally I have troube getting the car into 3rd gear. Sometimes it takes a couple of tries. Will the shifting smooth out over time or is this something I should see the dealer about?
Jerome
jk4music is offline
Old 09-20-2006, 10:19 PM
hammeron
hammeron's Avatar
Default RE: Trouble w/ 3rd gear in '07 GT
well if you really get on it and bring the rpm's up to say 4500-5000 (in second)
and then try shifting to 3rd, it's tough for me as well. I have 2000 miles on
my baby and it hasn't gotten any easier.....
This is with the stock shift kit....
hammeron is offline
Old 09-20-2006, 10:22 PM
jk4music
jk4music's Avatar
I have about 1000 miles on mine. Does the dealer say this is normal?
jk4music is offline
Old 09-20-2006, 11:36 PM
1fast05GT
1fast05GT's Avatar
Not normal. You shouldn't have to rev up to switch gears. It should go right in with the same effort as the other gears.
1fast05GT is offline
Old 09-21-2006, 01:20 AM
androdz
I ♥ Acer
androdz's Avatar
This is caused by the transmission binding at high rpm. This problem is because the shifter is bolted to the chassis and not to the transmission. They are two ways around it. Either get better engine/transmission points (polyurethane) or do like I did and get the K-member brace with torque limiters both will fix it completely. The difference is one will just damage completely your ride experience from all the shaking at idle and the other will not. Here is mo info:
https://mustangforums.com/m_1832846/tm.htm
Att. Andrew
androdz is offline
Old 09-21-2006, 09:40 AM
1fast05GT
1fast05GT's Avatar
ORIGINAL: androdz
Att. Andrew
True but I think he's talking about normal driving which shouldn't be a problem. Even when I go to the track I don't have problems power shifting into third gear. That's about to change when I install my Turbo from PH. I already ordered the K-member brace with torque limiters.
Old 09-21-2006, 08:48 PM
androdz
I ♥ Acer
androdz's Avatar
Normal driving no, but I have had the trans bind on me a couple of times racing. Either get either of the mods or just throw the shifter a tad more to the right like almost hitting 5th.
Att. Andrew
androdz is offline
Old 09-22-2006, 03:46 PM
Johnnie D
Johnnie D's Avatar
1,000 and something miles on my '07 no shifting problems even under full throttle..
Johnnie D is offline
msavoia23
12
07-07-2018 12:08 PM
Steve_05GT
10-19-2005 01:21 PM
cobraride
08-10-2005 04:11 AM
cobraride
08-09-2005 10:56 PM
joshv601
04-02-2004 05:36 PM
Quick Reply: Trouble w/ 3rd gear in '07 GT
