improving gas mileage
RE: improving gas mileage
On any given car, by far, the most radical swing in fuel economy is the drivers style. Keep your car properly maintained with as little weight as possible, keep a close eye on tire pressure and drive with a light right foot. The last part is quite a tall order given the car that you're driving.
Good luck.
Good luck.
ORIGINAL: MBDiagMan
Good luck.
Good luck.
Anyway, to elaborate on mods: most of the time, adding HP and adding Mileage are conflicting goals.
An engine is a machine that converts gasoline into power. Most mods that add power are simply mods that enable the engine to burn more gas, thereby making more power. After all, power has to come from somewhere.
For example, aftermarket intakes allow more air to enter the motor. This additional air enables the engine to spray in a little bit more gas, and that's where the HP gains come from.
If your primary concern is mileage, then you need to focus on mods that improve the efficiency of the engine or the car in general--not those that add HP outright.
Mods that remove weight from the car, especially rotating weight, can increase your mileage. There are a couple of threads (including a very recent one) about weight savings. Remove all the un-needed weight that you can, especially rotating weight.
UDPs will free up some parisitic HP loss, that will give you a small milege boost.
If you drive on the highway a lot, consider taller gears.
Intake and exhaust mods CAN under some circumstances provide you with mileage as well....but as in all cases, it mainly comes down to your foot. If you put on UDPs and then drive around with a lead foot, your mileage will go DOWN, not up.
Also, if you plan on doing this from a cost perspective, do your homework first. A $300 mod will pay for a LOT of gas, especially when you're talking about gaining a small amount of mileage from the mod. It may well be cheaper to just pay the gas bill.
ORIGINAL: forgotten
What would be some ways to improve gas mileage without sacrificing power(lower gears, etc.)? Or, what would be improvements that improve gas mileage and horsepower and response?
Drive like you have an egg under your right foot!!!
Taller gears on the highway will help as well, but your acceleration will suffer, but heavy acceleration violates the first rule above!
Looks like 3.08 is the tallest gear that comes from FRPP:
http://www.fordracingparts.com/parts...rtKeyField=833
So if you have a manual with the 0.68:1 OD you will have a final drive ratio of 2.0944
If you have an automatic with the 0.75:1 OD you will have a final drive ratio of 2.31
Those are real tall highway gears!
Hope this helps.
Mike
ORIGINAL: forgotten
Less weight in the car.
More air in your tires.
Steeda KVR 2-pc rotors
In other words, less rotational mass/weight and less resistance to rolling.
Will these mods pay for the gas, I doubt it, your foot will save the most gas, watch that throttle!
A 93 octane tune with the stock air box will give a slight increase in gas mileage at least it did for me. I drove around like that for a while, then I installed my Steeda intake (my mileage dropped after that.)
ORIGINAL: MikeVistaBlue06
+1 to CrazyAl
Hope this helps.
Mike
ORIGINAL: forgotten
Hope this helps.
Mike
welcome. now i must say it saddens me that your
already stressing about 1-2 mpg. imo, you'll never
truly enjoy the car, until you say f the mileage...
and imo, there are zero (practical, cost effective) ways
to improve your gas guzzling efficiency
good luck and post some pics when you can
Funny timing to see this thread. I have a stock except for FRPP suspension pack 06 GT manual. The past few days I have been trying to drive with an eye towards fuel economy just to see what is possible around town if I make an effort.
With fresh air in the tires @ 32 PSI all around, the A/C off, shifting early and an extra-light right foot I have been able to manage right at 20 MPG on my normal around town commute. This is 100% suburban surface street driving, zero freeway miles. I have found that the main thing that hammers fuel economy (besides the right foot) is being stuck in stop and go traffic. If the traffic is flowing, 20 in town is possible.
BTW normally I have been getting more like 16.5 (or less) around town.
Kevin.
Kevin.
