installed adjustable control arms last night
yes it was really easy, didnt take that long at all, although i didnt have the tool to measure the degree of the pinion i just basically left it a the stock degree, but over all it was less than an hour, in the garage with a jack and stands, i changed my spark plugs to, and i got to finally put a new belt on since it broke last sat night
RE: installed adjustable control arms last night
The steeda springs don't drop you too much but I would definatley get an angle finder and check it for sure. Your pinion angle should be anywhere from 2.0 to 3.0 degrees but I know some guys are running 1.5 Make sure to measure from the pinion flange and rear of the driveshaft.
Dragonus18
09-09-2015 01:21 AM
09-01-2015 08:16 PM
