Denny's Driveshafts
#23
RE: Denny's Driveshafts
ORIGINAL: PRGT
Ok thanks but what do I need to do to get in the groupbuy? I have one problem and is that I live in Puerto Rico. As for the your answer what do you mean by the rear? I am changing the differential with a detroit true-trac ad I will also buy the LCA.
#24
Do you thinkthat ifthecar is loweredthen itneeds an adjustablepanhard to fix the problem or what else could it be? BTW what about this driveshats? http://dagostinoracing.com/index.php...78_1_1110_3418
#25
ORIGINAL: PRGT
#26
Bought the Denny's at PMP. Its only 3 instead of 4 or 3.5 inches so that is a big plus. The one at D'Agostinoracing did not say the size or really that much about the shaft but I have heard that the DSS shafts are not that bad.
