Saleen Intercooler advice
Hi,
I have 2005 Saleen SC281 stock& live in U.K. where at the moment the outside temperature is just atzero c & getting less, Saleen is weekend toy so only used on occasions,quick question: out today, not much use of s/charger due to heavy traffic/road conditions, checked under hood on return home (habit) intercooler pipes, heat exchanger& fluid in resevoir cold.
Is this normal?
Thanks
Is this normal?
Thanks
RE: Saleen Intercooler advice
As long as your ICcoolant pump is working theneverything is fine. Turn the key to the on position, in about 20 seconds the pump should kick on even if the motoris not running. You can also open the resevior tank to visually check that your IC fuild is moving through.
mungodrums
09-28-2015 10:54 PM
