BATTERY DIES EVEN IF REPLACED
RE: BATTERY DIES EVEN IF REPLACED
Same here. Mine sat 17 days recently, fired right up no problems! Had the security system then some. No parasitic problems with my system thank Ford! ;-)
It's an '07 too.
It's an '07 too.
Try to diagnose it yourself , since the dealer is BSing you. Put an amp meter across the battery terminals, take the lid off the fuse box and use a small needle nose plier or fuse puller and remove and re-insert each fuse at a time. This should locate the circuit that is drawing power.....I, personally would start with pulling the fuse to the radio HU.
Me too.
ORIGINAL: MyGrabberOrangeGT
I just woke mine up after 2 weeks of very cold weather. Started right up. I always lock it with the fob so the security is on also. I do turn off the shaker though before shutting down.
