Speedometer Change with new Gears!!!
So I found a calculator for the speedometer difference with a gear swap. Is a 20% difference about right going up to 4.10 with the 05 GT's stock gears? Basically the speedo at 100 i'd really be going 80? Also does it have an effect on the Tach?
RE: Speedometer Change with new Gears!!!
It has NO effect on the Tach... that is driven off of the ignition and simply displays the RPM of your engine.
However, having different gears, your shift points WILL change.
If you have a tuner - SCT or Preditor, read your book, it will tell you how to reprogram your car so the speedo will display the correct speed when you change tire sizes or gear ratios.
Luke9222
10-22-2015 11:55 PM
musnicki
09-23-2015 07:11 AM
09-03-2015 07:14 PM
