Rev/tune question
Rev/tune question
Just a quick question.... I have noticed that with a stock tune and your car in neutral if you rev the motor it only goes to 4K.. Thats fine but why do the rpms come down so slow? I know its not that big of a deal but you cant just rev the car quick you have to plan ahead...lol. I just like the snapy revs not the long drawn out ones. I have a tune coming from brenspeed and i was wondering if your rev limiter changes or if it still uses the 4k rule. thanks for the help.
RE: Rev/tune question
I don't know why your stocktune would stop at 4k. I believe the stock rev limiter is set at 6,200 rpm. I didn't see the same behavior you are seeing.
The tune I got from Brent had the limiter bumped up a bit and you can really set it anywhere you like.
As to your second issue: The custom tune completely cured my throttle lag on the 'front end' and really helped the throttle hang on the 'back end'. I know you'll be pleased.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
