A/F question
A/F question
So I'm very new to doing my own maintenance on my car. I've got what I would consider an abnormal amount of 'soot' buildup on my tips and was concerned this was caused by the engine running too rich. On the advice of a friend I checked the spark plugs but didn't find anything wrong with them. (Just a few bits of light brown coloring I was told is normal).
Other than getting a dyno tune (expensive around here) is there another way to definitively check my A/F. Could it be as easy as the datalogging function on my Predator?
RE: A/F question
One way is to get a wideband gauge....... it uses a special sensor and spits out your A/F ratio not just reach or lean but actual numbers......
I am using the AEM one and I can either just look at the gauge readings or hook it up to my Xcal-2 for dataloging, I am not sure about the predator thought......
here is a pic
here is a link for info http://www.aempower.com/ViewCategory.aspx?CategoryID=67
here is a pic
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
