Cams in, here are the numbers
#21
RE: Cams in, here are the numbers
jwgroovin,did you run it at the track before and after? I'd be interested to see how that affected your times.
Yall have talked me into putting cams last on my list of mods if not taking it off entirely.
#22
Jon: Sorry to hear that man. . . thanks for taking the risk, though. As some others said it's helpful for us anyways. . . You've still got the best sounding 05 mustang out there!!!
#23
ORIGINAL: dirtydeedsinc
Will hit the track this Friday (unlikely) or Sunday May 27th (likely). Too many weekend to-do's...
#24
ORIGINAL: northy_polk
John
#28
Just an FYI - there is more to the Livernois stage 3 than just the 1mm ovrsize manley inconel valves. Just about every body uses them and make sure you are getting intake AND exhaust valves.
But what is equally important and you should make sure you get with a good set oof heads is new Titanium springs and retainers, new lifters, brass valve guides, and new rockers. Those are things you also get with the livernois stage 3.
