Cold air intake
Who makes a cold air intake that i wont have to "calibrate" my motor. For some reason i dont feel comfortable doing that, and its like 400 bucks for a one time peice. I was dead set on the steeda cold air intake, but then i found out you had to calibrate the motor. I kind of want to get rid of that big rubber peice off my motor as well. So what can i use?
RE: Cold air intake
i highly recommend getting a tuner with whatever cai you get.
Why don't you feel comfortable with it? |
RE: Cold air intake
Most CIA's require a tune and that is where you will pick up the realHP. I am running the Steeda CAI with SCT/tune along with Steeda underdrive pulleys and the IMRC delete and am very happy with the results, 311 RWHP and 328 RWTQ.The averagestock GT with a 5 speed clocks in on the dyno with around 273 RWHP.The mods I choose ended up being worth about 38 HP at the rear wheels. It was a good bang for the buck. The CAI and SCT/tune was worth probably 25 of that pick-up which is the best bang for the buckanyone can do to a Mustang.
[IMG]local://upfiles/63299/B1999BAEE1114AD9A0A085F763108AE9.jpg[/IMG] [IMG]local://upfiles/63299/2EA6DC7A0F6B4A0B99B2E6D66355CCFB.jpg[/IMG] [IMG]local://upfiles/63299/879D7C4955BD401B83FE355EE114E105.jpg[/IMG] |
RE: Cold air intake
im afraid to void the warrenty, plus like i said, im paying 400 $ for a one time thing
RE: Cold air intake
It's not just a one time thing, the tune can be modified as needed for any other mods you might be doing down the line. All in all a tune is the best bang for the buck.
RE: Cold air intake
ORIGINAL: chupac It's not just a one time thing, the tune can be modified as needed for any other mods you might be doing down the line. All in all a tune is the best bang for the buck. |
RE: Cold air intake
okay so you just plug it in and fo what it says? sorry guys im a noobie
RE: Cold air intake
That's exactly what you do. Just make sure you get a tune for the cai you are going to use.
RE: Cold air intake
You can also set the speed/rpm limiter if you ever loan your car to someone or take it to a body shop. There are lots of things you can do with a tuner. The SCT has prompts for you to follow. I'm not a gear head and even I could follow the prompts and do my own tuning.
RE: Cold air intake
yeah im gunna get one, you guys convinced me
