Occasional noise at startup? 06 GT
It sounds like the tickingfrom the air compressor when ac is on, but in this case it’s not on and it's only a single click when engine turns over.
Engine Mods: Jlt Intake&Shaker Hood Combo, and Steeda Udp’s.
If this has been discussed already, please point me to the thread.
Thanks
Thanks
RE: Occasional noise at startup? 06 GT
What mods do you have? If my che torque limiters are loose, they will make a click noise when starting and turning off the car. It could easily be the exhaust making noise or any number of other things connected to the engine.
My advice is get some poly motor mounts and see if it goes away. They will make shifting at high rpms easier and keep the engine from moving so much at start up, so hopefully solve your click problem. I bet its just the exhaust flexing or something similar.
Poly engine mounts will cause more engine noise to find it's way into the cab, but it's not that much. Makes the car feel faster. If you allready have poly engine mounts then you're SOL.
Sorry, I posted this also overto: https://mustangforums.com/m_3382581/tm.htm
My first post wasplaced here, but response wasn't nearly as quick.
Thanks
Thanks
KingRando
10-02-2015 08:06 AM
