um...can we define "whine"?
RE: um...can we define "whine"?
I noticed you have aftermarket lower and upper control arms. I had my gears done before my suspension modifications and they were absolutely quiet. Once I added my lower controls I started noticing gear whine.
its called planning for the future.....if he gets a one piece DS or lowers the car, he will need them......no sense in spending a couple hundred now only to have to spend 250 later for new ones!
ORIGINAL: howarmat
I plan on non-adj LCA's and adj UCA. One point of adjustment vs 2 which could possibly lead to other issue's, and you shouldnt have to change the pinion angle once done unless you change ride height.
^^^ http://www.royalpurple.com/mediaa/mediaa.html
not saying you got the wrong one, but here's a link to the 75w140 rp...
acutally you'll have to click on "round quarts" on this link to view the gear oil (oops)...
ORIGINAL: rravolt
thanks just went and returned it and got the 75w140 thanks again for the correction i would of been ****** if i found this out after the gears were in
