Inputs from Superchargered Stangs
I finally have the money to start doing serious stuff to my car, obviously from the title you can see a supercharger is on my list. What I was wondering is what gears are you guys running? I have 4:10s in the rear now, I was going to stay NA but changed my mind, but I was told to go back to the 3:55 gears. The car will be a daily driver, so I can handle being a little slower, but I wanted to get opinions, experiences, any track data, etc. I just want to see if I NEED to spend the money to change the rear-end gears back out. Thanks for the inputs.
RE: Inputs from Superchargered Stangs
Get the supercharger then decide if youwant to change your gears or run a taller tire.
I'm running 3.73s with my Kenne Bell. |
keep the 4.10's... changing back is a waste of money. use the money towards long tubes!
I'm happy with the 3.73's with my current set-up (details in sig) but I don't think that you NEED to change back. I see quite a few folks in here that are supercharged and running 4.10's. I would say get the supercharger first, see how it drives and then decide if you want to change them. Good luck and let us know what set-up you go with.!
I just had a supercharger installed last week. It runs fine with my 410s.
