Car hesitation!!!! please help
RE: Car hesitation!!!! please help
ok so i pulled a few of the plugs and they kind of have a grey color to it.i dont see any rust visible, or oil, and its certainly not black. so my guess is lean? there motorcraft platnium PZT 1F
The gas pump issue is something the dealer can fix.
The other issue... How much boost are you running, and what size injectors do you have? Are you running a Boost-a-pump or just a stock Fuel pump?
Gut reaction on what you have said so far.. is Fuel starvation, likely from a fuel pump dieing... but that being said, could be other things as well.
will the dealer fix the fuel pump for free? its not a recall. i went out and bought a scanner that is C/A/N compliant. so i hook it up and it says camshaft position sensor bank 1. the connector is bad. im ordering a new one.
if the car is still under warranty, there's a chance that
the dealership will replace the fuel pump, if they find it
to be faulty
that's interesting about the sensor, gotta love scan tools
to be faulty
DrunknRuckus
08-23-2015 10:05 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
