what fuelsystem does well for 600hp?
I have a keene bell supercharger on my 05 gt and I want a fuel system that can handle the hp. The car surges a little when I get on it and even when Im driving down the highway. Ive heard of putting twin fuelpumps on it but the boost-a-pump from Kenne bell was supposed to take care of that problem. What would you guys do in this case?
thanks
Matt
thanks
Matt
RE: what fuelsystem does well for 600hp?
If for some reason the KB BAP wont do the job and it is that big of a problem, it looks like this GT500 fuel systempackage from Brenspeed will do the job. However, it is a tad pricier than a BAP
Good luck
thanks for the idea, that is a tad bit pricey. When I get my car down here I will take a real good look and see if I can justify a new fuel system. Im hoping it is a cheaper fix than that lol
thanks again
thanks again
If it is surging in normal driving I wouldn't think that was a limitation of the stock fuel system. Dunno how much more power you are pushing than I am but I have the stock fuel systemplus a BAP and it works great.
You may want to put her on the dyno and do some diagnosis.
One of the members here running a Hellion kit and pushing 550 hp on a forged stroker *was* using the GT Supercar dual setup but switched to the GT500 pumps. Seems the GT duals weren't keeping up (as odd as that sounds).
yeah i was running the dual GT500 pumps and had pressure problems at 510rwhp. The air/fuel still showed ok, but during the dyno tuning Brenspeed was somehat concerned because normally they don't drop off like mine was doing. I was shooting for 600rwhp, so I decided to just order a full blown system from MMR and not risk anything. I may have just gone with the GT500 setup but Brenspeed wasn't selling them at the time. Just a note though, my car did not demonstrate what they usually see on the dual GT pump setup.
I have a Kenne Bell 2.6L with the boost a pump
I'm having the same problem
I think the boost a pump is boost activated in the tune
I'm not shure but I think there is a way to wire the boost a pump to be on all the time, you could try that trick
Also there is a TSB (Ford recall) for a bad fuel pump (hesitation after a long cruise) check to see if your pump is recalled.
I just got the GT 500s pumps, but not installed yet
I'm getting them installed next week I'll let you know if I feel any difference
http://www.2005stang.com/gallery/alb...hesonaccel.pdf
