Advise on Pypes mid-muffler
Hi all. I'm a newbie, but I've done a lot of research on the forums. I'm going to order the Pypes mid-muffler system purely for the asthetics. I don't have a CAI, just the K & N reusable filter. Do I need to buy a tune once I install the Pypes? Does anyone know if the MPG will go down a lot? It's my daily drive in CA. Mostly stop & go city miles. I currently average 12-14 MPG. Thanks.
RE: Advise on Pypes mid-muffler
I have them with Cervini's side exit exhaust. With the Stock Catted H pipe they sound really nice. I had the Pypes ORH and they were so loud I couldn't take it.
No tune is needed & your gas milage won't change. I did have sone issue with the hangers on the pass side rear pipe, you might have to heat/bend the hanger rods slightly to get the tips lined up properly.
Also, if you're not using a lift to install, you'll need to unbolt the rear shocks @ bottom end,jack the car up a bit more to get the stock over-axle pipe off. Tight fit on the muffler to tank clearance.
They sound good with the stock H-pipe & cats. I've got a video of mine here;
http://www.youtube.com/watch?v=fANDdIp2GjY
I'll be installing long tubes here in a few weeks on mine.
Use of a lift is highly suggested. you won't have to heat bend the pipe at all you just have to muscle it in a little. Use of a lift will prevent you from having to remove any of the shocks as suggested earlier. Its pretty easy and you won't have to order any other hardware just useyour existing hardware.
I got BBK shorty headers into a Pypes X pipe with cats, and Pypes M80 mid muffler pipes. I found that the clamps Pypes sent were junk I had all kinds of exhaust leaks which I cant stand. I ended up getting the whole system welded and 3 1/2" tips from the axle back. Looks and sound way better than the cheep 4" tips they give you. Enjoy the sound of your pony.
Thanks for the advise. I'll try it out w/ their stuff. If it doesn't workout, I'll call a few muffler shops for quotes. How much did the welding and the new tips cost (if you don't mind)? Thanks.
