Ordering internal parts. Advise needed
RE: Ordering internal parts. Advise needed
I'm glad you decided against the probe pistons. Though they have some great success on other applications, I don't like their dish for the S197. I had a set of probes in my first build and they sucked. The Manley's are decent and a lot of people use them but I like the coated JE's above them all. I have looked at a lot of pistons and like the design of the JE's for the modular motors above all others.
As for your compression, you certainly can run a high compression with big boost. As a matter of fact, the blower will love it. The problem comes in octane. Is this going to be a track only car?
I ask because Justin should have certainly told you that with a high compression and big boost, race gas is going to be mandatory ALL THE TIME. You will not be able to run pump gas in that set-up. If you're going where I think you're trying to go, you'll be dependent on C16 (118 octane) and that sheet is no joke to your pocket. I spend upwards of $500 a month on the stuff just for the track. I can't imagine what it would cost me to run it on the street full time as well. This is the reason I have a 8.7:1 instead of a 10 something.
Yes, for track power, you want higher compression but always remember that higher compression requires higher octane.
Im going to call Justin tommarrow to make sure but I think I should go with a 8.5:1 or 8.7:1 to run 20 psi on 93 oct for the street as this is were I play and I only see the track 1 time per month but dont get me wrong I want 1000 bhp that is why this combo has been hard to decied on.
ORIGINAL: ebr
Well here is what I decided on but Im getting the kit and not the short block so I can have everything ceramic coated at Polydyn.
MMR 5.0 STROKER Street Mod 1150 (up to 1150HP)
This STROKER shortblock adds .4 liters to your Mustang engine without anyone knowing, all factory parts bolt right on! Great for blowers, turbo or Nitrous. With no other changes this Stroker shortblock will add up to 40HP and 40ft lbs of torque! This shortblock can support up to 1150 Rear wheel horsepower!!
*Brand New Cast Iron 2004 Cobra Block, torque plate bored and honed
*New 4340 Manley Pro-series Billet Rods w/ARP 2000 Rod bolts( These US made rods are shotpeened, magnafluxed and weight matched to bring you the finest I-beam rod available for your 4.6
*New 4340 Forged 3.750 stroke Crankshaft w/micro polished journals at no extra charge
*New MMR/ Manley or Diamond pistons 3.552 Bore size (High or low compression)
*ARP Mainstud kit
*Speed Pro file fit rings (precision file fit to your application, nitrous, blower, turbo or N/A)
*Speed Pro/Federal Mogul Race series Rod and Main bearings
*Complete Pro Assembly and Balancing for the smoothest, highest revving shortblock available
*ARP Mainstud kit
that's going to be a killer set up if you do go with 20psi..
which site is that from? links> please?
In need of some assistance
I just bought my 2006 Mustang GT and its only got 5,xxx miles on it so I don't really want to go in the motor...but I want to do something to it. I wanna get a Bassani H-Pipe and long-tube headers, either 4:10s or 4:30s in the rear end. And a throttle body. Any ideas of other small things I could do to increase HP and Torque are welcome.
DrunknRuckus
08-23-2015 10:05 AM
KEM Motorworks
08-14-2015 10:13 PM
