FRPP 4.10's are here but I've got a question
My gears showed up but can't find any pinion depth or backlash specs on them anywhere. Has anyone else run across this? I've installed alot of gear sets over the years, and this is the first set I've seen without the specs scribed on them.
RE: FRPP 4.10's are here but I've got a question
I set my backlash at .010. I also used the original shim behind the pinion, mine was .029. If I was installing the gears, I would start with the original shims and see what kind of pattern and backlash you end up with. I installed 3.73 and used original carrier shims and pinion shim. I have no whine and my backlash ended up at .010. I hope this helps.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
junior04
09-28-2015 10:53 AM
