top speed on 4:10 auto?
what is the top speed on a automatic GT with 4:10s intake,tune and full exhaust?
as opposed to one with the 5 speed?
and does it begin to slow down past 120 or so? with enough power it should get right up to 155 top speed correct? not planning on topping it out or anything but not exaclty wanting for it to fall flat on it's face by 120 lol.[:'(][:'(][:'(]
RE: top speed on 4:10 auto?
well i may have to step down from the 4.10 to a 373 in the 1/4mile because im hitting 123mph in 4th gear, but im really getting close to the shift point maybe 8more mph to go.
I have much faith that with your mods you can get to 155 in 5th
ORIGINAL: Jeremy05
ORIGINAL: kcmarti
What formula are you using to determine top speed by rpm/gear ratio?
http://www.car-videos.net/tools/speedrpm.asp
Nice tool, thanks. Hmmm... using that calculator, I would be doing 500RPM more at posted highway speed (65) - doesn't seem like to much more to me. I may go to4.10 instead of3.73.
ORIGINAL: kcmarti
Keep in mind that the linked calculator providesonly theoretical numbers - if there isn't enough power at whatever rpm to push the car along at that speed, you won't get up to that speed (without tailwind or downhill assistance or some such). Nor does it consider slippage across the torque converter in automatic-tranny cars. I don't know whether a lockup converter stays locked up at those speeds or engine rpms, but if it doesn't you'll lose several mph even though you might pull the full 6000 rpm.
Estimating a real-world top speed also requires halfway decent estimates of aerodynamic and rolling drag as well as torque/horsepower curves.
Norm
ORIGINAL: kcmarti
Norm
