351 windsor swap
RE: 351 windsor swap
If you have a GT, it's not worth IMO, unless you stoke that Windsor. Now we're talking
If you plan to do this regardless, it will be a lot easier with a carbuteror set-up.
Fabrication will be in motor/tranny mounts and custom DShaft. You'll prolly need a different fadiator, custom PS/AC hoses.
If you go fuel injection, you will need an electronic Guru.
If I can find another LL, preferably a sixer, that's what I'll do... 427ci out of the 351 block and 500+hp at the wheels N/A. All of this matted to a six spd tranny, yes!
Anyway, good luck. I wanna see this.
BMR makes a k-member for the s197 to put a windsor swap with the mounts. You also get to use the stock Power Steering Rack. You just need a tranny, DS and wiring. I already looking into it. Check out BMRs website.
http://www.bmrfabrication.com/2005MustangCHASSIS.htm
Its the KM012. That will be all you need.
ORIGINAL: pascal
Or maybe one of these puppies.......
http://www.youtube.com/watch?v=jsKvrfyULhU
thanks a bunch guys. very informative. and yea i dont plan on dropping it in as a 351 haha. i just had a friend crash his truck and he just put a 351w in it with 10k miles on it and se said hed give it to me for 300 so i was just weighing the options. but yea i plan on building it up before it goes in. and in the meantime im putting comp cams in the 4.6 in the car sunday so well see how that goes =)
