Rear End Fluid Change - Difficult? DIY Guys Please Chime In
RE: Rear End Fluid Change - Difficult? DIY Guys Please Chime In
Yes the cover needs to be removed and it wouldn't be a bad idea to replace the cover with a girdle if you ever drag race. Even if you don't, it will allow you to change the fluid without removing the cover next time. LPW makes a girdle for our cars as well as ford racing.
You'll need some grey rtv sealant.
http://www.permatex.com/products/aut...sket_Maker.htm
Or you can purchase a gasket for the ford 8.8 like I did ( the frpp girdle comes with a gasket, but I wanted something bullet proof.) This is the one i'm using.
http://www.knowwhere2jeep.com/catalo...ehjrda3r7ak2v5
Warning! Gear oil is nasty, slimy, stinky stuff. You'll also need a bottle of friction modifier from your ford parts department, cost $5.
Be sure to stay with a synthetic 75W140 gear lube, and yes, use the friction modifier regardless of what the gear oil company says - you need it.
I found an upgraded rear end gasket, I think it's called Lube Locker. A little pricey, but it can be used over and over and it hasn't leaked a drop. That RTV stuff is a pain. Read your owners manual too, it tells you how much lube to put in, you don't fill it until it runs out like you used to .
ORIGINAL: Goldenpony
ORIGINAL: moosestang
See my link in my post above.
BINGO! Same one I used. Neat part.
Get a syringe <sp> and some clear tubing, so you dont even have to take the diff cover off. This is how they do it at the dealerships, and quick lube places. Refill with what fluid you want to use.
ORIGINAL: wasvette
So if I go with Royal Purple, I still need to add the friction modifier even though they say it is not necessary?
I would not do it this way (the syringe). It's better to be able to wipe out the bottom of the housing with paper towls and get any "garbage" there before you refill with fresh lube.
Anyone have instructions on how to do this? Also besides oil spilling out is there any danger of parts (gears) falling out or anything? Sorry I just have never been this involved with a car, trying to learn
