frpp bearing kit
frpp bearing kit
So im finally about to pull the trigger on the frpp 4.10's at american muscle. However they only sell the motive bearings kits. Where can i go to find the frpp bearing kit, and do i need the installation kit or the whole master bearing kit, or both? I have 17,500 miles so id rather just replace everything in the diff. to avoid problems down the road. Also will i need to get gear oil or will it come with one of the kits.
RE: frpp bearing kit
The FRPP install kit is available at several locations, this is where I ended up getting mine...I did the complete kit. For a 40 or so dollar difference, it was not worth the concern for me....
http://romisher.tzo.com:8006/frparts...partstype=REAR
I also purchased the gears and FRPP Racing Girdle from them as well. As far as the gear oil, it does not come with the kit. It is a personal preference type of thing. I personally went with Royal Purple gear oil from Brenspeed.
You will love the 4.10's......
Mike
Mike
Yes, the B install kit is what I went with. Includes everything from the A kit, plus.....I don't know if that is equivalent to the motive kit, since I did not consider it.....
It was my experience that vehicles under 60k miles only needed the basic install kit, plus an inner pinion bearing and race which canbe found at any Ford dealer. I think I picked my FRPP install kit up at Summit IIRC.
ORIGINAL: mlcrycc
Mike
Mike
Am. Muscle sent me the Motive bearing/install kit with my FRPP gears. That should work right? I hope? I never questioned it since Motive makes the FRPP gears I just figured AM. Muscle knew what they were sending and it was cool. I've had mine longer than the 30 day refund policywaiting on my installer and the bucks for the labor.
ORIGINAL: 00silverStang
Do you have a link to the frpp girlde, thats the one where you dont need the adjustable panhard bar correct?
ORIGINAL: mlcrycc
Mike
Mike
Pic shows what it looks like.
Mike
[IMG]local://upfiles/13557/034422D948704C9ABED6DEF16B5C0C6B.jpg[/IMG]
