Picked out gears, but which install kit?
I'm finally settled on which gears to get (4.10 FRPPs), but which of the following 3 install kits do I need to get?
397-M-4210-A $41.99
Includes pinion and carrier shims, crush sleeve, pinion seal, pinion nut, ring gear bolts and cover gasket
397-M-4210-B $83.99
Includes pinion and carrier shims, crush sleeve, pinion seal, pinion nut, ring gear bolts and cover gasket, pinion gear and carrier bearings
397-M-4210-C $111.99
Includes pinion and carrier shims, crush sleeve, pinion seal, pinion nut, ring gear bolts and cover gasket, pinion gear and carrier bearings, axle shaft bearings and axle shaft seals
I'm thinking the "C" is not necessary, but which between "A" & "B"?
397-M-4210-A $41.99
397-M-4210-B $83.99
RE: Picked out gears, but which install kit?
Aaaagggghhh~!!
I got my gears....and something else the dude said I would need to have them installed with......but I have no idea if he gave me what I needed ?? [>:]
Damn gears!
Damn gears!
NorthAmericanTuning
03-18-2016 11:21 AM
