SCT/CAPABILITIES
RE: SCT/CAPABILITIES
ORIGINAL: GT Bob
The only thing the extra adjustability will make easier, is making your engine go boom. Seriously guys,there are literally THOUSANDS of tables that can be adjusted and played with. Each one does something different from the rest, and if you just blindly adjust things without understand how each table works with the others, you can be making a recipie for a blown motor.
ORIGINAL: ChiDiddy
i'm interested in using the SCT ProRacer Tuning Software with the SCT Xcal2 flash tool
http://sctflash.com/PRPFord.php
From the looks of it, its much easier to adjust parameters (perhaps gives you even more tunable parameters than the XCal alone) and easier to see your adjustments and datalog the same time.
Andrew
