gears no tune? ..yet.
Old 04-22-2008, 11:30 PM
stealth_GT
stealth_GT's Avatar
Default gears no tune? ..yet.
Gonna get the intake tuner kit anyways but if I get gears first will they still be as noticable
without a tune??
(auto)
stealth_GT is offline
Old 04-22-2008, 11:42 PM
howarmat
s197 Junkie
howarmat's Avatar
Default RE: gears no tune? ..yet.
the tune has nothing to do with the gears other than it tells the computer what gears you have in the car....i wouldnt drive an auto without this setting changed
howarmat is offline
Old 04-22-2008, 11:45 PM
desslok40
desslok40's Avatar
NO !!!! I made that mistake, got 3.73 gears, re-loaded my tune and changed parameters for axle ratio to 3.73, speedo wascorrect but I really didn't feel any difference with the 3.73s, contacted Doug and Bamachips and he said its common for people to think all you have to do is changethe ratioin your tuner, unfortunately the actual tune needs to beset-up for the gear ratio, so without in theory if you are stock, the stock program is set for stock 3.31 gears, just like everything nowadways the computerrules not the actual mechanicals!!! [:@]
Get a SCT Xcal tuner with a CAI (Brenspeed or Bamachips), 3.73 gears, you will not believe the difference those things will makeespecially for an auto.
Good Luck
desslok40 is offline
Old 04-22-2008, 11:50 PM
stealth_GT
stealth_GT's Avatar
ORIGINAL: desslok40
Good Luck
dang it..wanted to get gears first but I guess I'll just get the I/T kit first lol.It'll only be like 3 weeks between mods so it's not like I'll be waiting forever or anything.
Pretty sure I'll get 3:90s though really really really itching towards 4:10s...I'll mod out with traction mods if I have to!!~
Old 04-23-2008, 12:11 AM
howarmat
s197 Junkie
howarmat's Avatar
he woudl adjust his shift pressure and points in an auto, but there isnt anything he can really do for manual.
howarmat is offline
Old 04-23-2008, 12:51 AM
SaddleUp
SaddleUp's Avatar
So if I already have Doug's tunes......and then had my gears installed.....I really need to contact Doug and have my tunes updated?? Is this the right understanding??
SaddleUp is offline
Old 04-23-2008, 12:54 AM
desslok40
desslok40's Avatar
Thats correct, you will still need to change parameter axle ratio to 3.73 or your speedo will be off (it will be real obvious!!!), but Doug will still need to update the tune and then you willbe good to go
Old 04-23-2008, 01:02 AM
stealth_GT
stealth_GT's Avatar
ORIGINAL: SaddleUp
that's one bad *** looking GT.
..so it really is best to get the intake/tuner then gears??
For some reason or another I want gears ASAP...
SaddleUp
SaddleUp's Avatar
So....maybe I should get my 20 inch wheels and 3.73 gears parameters changed on my tuner and then have Doug "re-write" my tunes......??
Damn...this modding thing never ends!
SaddleUp is offline
Old 04-23-2008, 01:22 AM
desslok40
desslok40's Avatar
First off, why 20s ? you driving a Hummer or something Get your tune adjusted before you get gears installed and then you are ready to load upthen drive off. Change the other stuff whenever you want but don't drive around like me for a week without the right tune [:@]
Quick Reply: gears no tune? ..yet.
