Problem with alum. driveshaft.
Old 05-21-2008, 11:36 AM
DeStonn
DeStonn's Avatar
Default RE: Problem with alum. driveshaft.
I am having the same issues as you. Right at around 80 mph my vibrates and feels like it is about to fall out. I have tried adj. uca and adjusted the pinion angle to where the - angle from transmission and + angle from the pinion were the same and still a vibration. I had a BMR adj UCA and this week I am going to Steeda.
I might have to try rotating the driveshaft so everything is the same as the original setting but that is gonna be a challenge because I don't think the original installer marked it. [:@]
I have the Coast 4" and the guys at Coast are always willing to help but I can never get it right. Almost ready to give up.
DeStonn is offline
Old 05-21-2008, 12:57 PM
Vapour Trails
Vapour Trails's Avatar
I have a steeda alum. DS that is sitting on my basement floor because the previous owner said it vibrated at about 80 mph. He removed it, but gave it to me when I bought the car. I'm still debating whether I want to pay a shop to install it and find out it sucks. This problem seems extremely common.
Vapour Trails is offline
Old 05-21-2008, 05:34 PM
jbailer
jbailer's Avatar
The problem is extremely common but only on automatics as far as I've heard. I'm guessing you guys have automatics that have experienced the problems. If so, I'd recommend going with the spyder shaft. I haven't had any problems with vibration at all with it. -Joe
jbailer is offline
Old 05-21-2008, 07:43 PM
STi Rob
STi Rob's Avatar
I brought the car to the shop today to try and find the cause of the vibration and no luck. The factory shaft is back on the car but the vibration is ever so slightly still there but not noticeable until over 100mph and even then you have to know what your looking for to notice it. The car will go back in the shop in a couple of weeks for one final attempt to remedy this situation.[/align][/align]Rob[/align]
STi Rob is offline
Old 05-21-2008, 07:55 PM
STi Rob
STi Rob's Avatar
ORIGINAL: jbailer
My carhas a standard transmission. What weve come up with to this point is that the shaft isnt to blame it just does a great job of transmitting the vibrtaion. I also think the lca's aid in this also. My shop is goingto try one more thing (something to do with the pinion) to try and get rid of the vibration if that doesnt work I guess its put her back to stock and get something else.
Rob
STi Rob is offline
Old 05-21-2008, 08:49 PM
moosestang
moosestang's Avatar
ORIGINAL: STi Rob
ORIGINAL: BoidMorphs
I have a Shaftmasters 3.5" aluminum shaft with Vogtland lowering springs, J&M adjustable UCA with J&M billet LCA's. My car is very smooth right up until 85 or so. The first time I went up over 100 I couldn't even see out of the rearview mirror due to the vibration. It's more of a high frequency buzzing type of vibration that is there at high speed.
I've read that adjusting the pinion angle can help eliminate it and with the Spydershaft, disconnecting the shaft and rotating it's mount 180 degrees cures it. I haven't tried either one of these on my car yet to see if either one will get rid of the vibration.
Anyone else try doing these to cure vibration issues? I'd like to know what the perfect setting for pinion angle is and how far off the original setting was.
It Sounds like you have the exact same issue I have. At about 100mph I also can not see out my rearview mirror due to vibration. Ive also noticed thatthe vibration gets a little worse when I let off the gas and start decelerating (no brake just coasting clutch in or out). The shop I go to has tried turning the shaftwith no success so they replaced the shaft altogether but that didnt help either. Im pretty sure they tried every trick, they worked on the car all day. Theyve installed ALOT of driveshafts and the only one they claim to have any problems with was one spydershaft and they were able to fix that (I actualy talked to the owner of the car).
If the problem gets worse on decel then you need to adjust your pinion angle up some. When you let off the gas the pinion rotates downward. When you are on the gas the pinion rotates upward. I wish i new how to upload the ford service manual instructions on measuring and setting the correct U-joint angles, because they are very different from what most people will tell you.
I don't know how your shop installed your driveshaft, but it's important to use the exact same orientation as the stock shaft. I would even go as far as to make sure the pinion flange and trans flange remain in the same orientation by marking them before removing the stock shaft.
Take a look at this picture.
That's my stock shaft at the transmission. Now imagine rotating the shaft 90 degrees in either directions. You can see you'd still be using the same holes, which is what you want, but the U joint is not the same on each side and this caused a vibration on my car over 70 mph. It is very easy to remove and reinstall the driveshaft at the trans. All you need is to support the car and a 12 point 12mm socket and breaker bar. You'll need a torque wrench to tighten the bolts back to 76 ft lbs. I would start by rotating it 90 degrees and see if it helps. unfortunately you don't know if your shop used the same holes, but you might be able to tell when removing the driveshaft. the stock driveshaft does a great job of absorbing vibrations at speed, not so good at being quite while driving slow and shifting though. No aftermarket shaft is going to be as smooth at speed, i'm afraid.
Keep in mind when you make something lighter, it usually means is will not dampen vibration as well.
You may need to turn the shaft at the pinion as well and even turn the adapter plate if you have one. It's going to take some trial and error at this point. Keep track of what orientations you've tried by marking it with a sharpie.
moosestang is offline
Old 05-22-2008, 04:25 PM
STi Rob
STi Rob's Avatar
Thanks for your input moosestang. I cant say for sure the exact procedure the shop uses when installing driveshafts but they do install alot of them with only one other complaint of vibration (that customers car was fixed simply by turning the shaft)other than me. The shop has one other thing they are going to try, Ill try and explain but Im no mechanic so I might get a few things wrong. I beleive it has something to do withthe way the piniion flange mates to the rearend or pinion gear, they said it is within ford specs but they felt it could be out enough to be causing my issue. If some one more knowledgable than me canexplain this a little better Id greatly appreciate this.
Rob
STi Rob is offline
Old 05-22-2008, 07:06 PM
Vapour Trails
Sounds like they are talking about the angle of the pinion flange.
Old 05-24-2008, 08:54 PM
sd07gt
sd07gt's Avatar
ORIGINAL: STi Rob
As the title says Im having a problem with my alum. driveshaft vibrating at speeds above 80mph. The shop where I purchased and had the driveshaft installed has been very helpful but the problem still persists. They even replaced the shaft with a new one but the problem remained the same. Im at the point where Im about to give up on the shaft and go back to the factory 2 piece.I know several people who have the same shaft as I do installed by the same shop and they have no problems whatsoever, I probably just have one of those few cars that has a tendency to vibrate. If anyone has any advice as to what can be done to stop the vibration I would greatly appreciate it.
Rob
PM SENT !!!
sd07gt is offline
Old 05-25-2008, 02:01 PM
STi Rob
STi Rob's Avatar
ORIGINAL: sd07gt
ORIGINAL: STi Rob
Rob
PM SENT !!!
Thanks.
Rob
STi Rob is offline
Seanam
10-04-2015 10:15 AM
mdj89
09-23-2015 08:49 AM
kachuy10
09-22-2015 01:27 PM
stangin1996gt
09-21-2015 11:01 AM
Big Al's 03
Mach 1 Section
09-21-2015 07:59 AM
Quick Reply: Problem with alum. driveshaft.
