Help choosing clutch, flywheel and slave
Slave in my 05 GT is giving me problems.At least i think thats the culprit. After like 15 miles of crusing in same gear clutch gets really really stiff. And you need to pump it a few times to get back normal pedal softness. So while i have the trans out figured i might as well upgrade it all.
Right now car is just bolt on's making 300 wheel horse power. Later down the road it might be blown so i was just gonna do it right now.
What clutch and flywheel do u guys recommend? Is it worth to drop the money on a aluminum flywheel? And should i get a upgraded slave?
RE: Help choosing clutch, flywheel and slave
Do a Spec 2+ or 3+ with matching flywheel ALONG WITH a Ram hydraulic TOB. As far as the flywheel, aluminum will offer slightly better performance at the track however some would argue that you lose some driveability on the street.
I personnally am doing a Spec 3+, matching steel flywheel, and Ram TOB later this month at Brenspeed.
From what I have heard, most problems with Spec clutches are from the "+" series. I would think about doing a Spec Stage 2 as they are rated for 599 ft #'s tq.
As far as flywheels here is my take.
For a drag car go steel as the launchs will be better with more inertia.
For a track car go aluminum as the reduced rotating weight lets the motor spin faster. I would think this helps with roll on races too for a street car.
I am still a little on the fence, but I think I will go Aluminum because I spend more time punching it from a roll, then I do launching the car hard from a stop.
Good Luck.
Good Luck.
If you have the tranny out and are looking at building it one time, get a twin disc ceramic, have the input shft redone to 26 spline instead of 10 and get a billet steel flywheel.
I have a fidanza allumenium flywheel and a ram clutch with 500 bhp and I havent lost an ounce of streetability. Ive got the kenne bell unit and have been happy with the whole set up so far.
junior04
09-28-2015 10:53 AM
ccdguy
09-19-2015 05:20 PM
