Dennys DS
Dennys DS
Hi, I installed my DS like 5 month ago. The thing is that after the install it vibrated a bit when I was over 100pmh or so. Like a month ago I installed adj. LCA since the install it vibrates when i'm at 70 or over and in deceleration. What can I do to fix this. I almost can't race my car because of this. Any advice is helpful. Thanks
RE: Dennys DS
What's your pinion angle set at? That can be part of the issue. Also, when you go to aftermarket arms with urethane bushings, you will get more noise and vibration transfered through the chassis.
Casey
Casey
RE: Dennys DS
If it vibrates on decel try raising the angle of the pinion. The vibration over 70mph makes me think you need to unbolt the driveshaft and turn it 90 degrees, but you should have felt it before the lca's. It wouldn't hurt to try turning the shaft at the transmission, it's easier to remove at that end. If you do this, be sure to mark the shaft now so you know where you started. I think you'll always have more vibration over 100 with an aftermarket driveshaft. The stock driveshaft does a wonderful job at absorbing vibrations, probably because it's so freaking heavy.
RE: Dennys DS
ORIGINAL: howarmat
yep, moose is correct, this made mine go away
