stock torque converter...
how much power can the stock converter handle?
can afford only the whipple h.o. kit + installation but not the converter just yet...
granted I won't be launching the car hard any time soon with that kit,should it be okay for daily driving and getting on it from a roll??
plan on running 8 psi at the most...
my 05GT was running with a saleen s/c, LT headers etc with 422 rwhp/ 416 torque on stock converter. our trannies and their components are rated at 360 hp i believe...my ran with the stock converter for about 1 year and 1/2 before I sold it. I drove it pretty freaking spirited. however never visited a track....the new owner has owned it 3 months and snapped the input shaft....so you should be fine.....good luck...
I am thinking hard launches/burn outs is what would kill it.
not sure but I will also try to get a tune from bama to make 3rd shift a little less aggressive if possible.
I might even consider the standard 6 psi 415 hp non-intercooled kit then upgrade later,it's $2k less then the H.O. and still makes great power.Advertised as 415hp but I assume it'll be something like 380-390whp (auto)
unless it is (415)whp then I'd be set with that kit for awhile..
20 passes so far, all is good. Best time thus far is 11.8's.
Your stock T/C will be easier on the input shaft than an aftermarket T/C. The input shaft, as well as 3rd gear are the "weak links" in these tranny's. For a little more piece of mind I would change your fluid to Amsoil or Redline if you haven't already. A larger pan is available and a few people are using it, however, I have not heard of a stock 5R55, properly filled, blowing up due to a lack of adequate fluid volume. So spend your money wisely.
Your stock T/C will be easier on the input shaft than an aftermarket T/C. The input shaft, as well as 3rd gear are the "weak links" in these tranny's. For a little more piece of mind I would change your fluid to Amsoil or Redline of you haven't already. An larger pan is available and a few people are using it, however, I have not heard of a stock 5R55, properly filled, blowing up due to a lack of adequate fluid volume. So spend your money wisely.
thanks for the info.
how is the stocker easier on the input shaft/tranny than an aftermarket one?
To make up for the difference in high stall converter launch would it be wise to install the 4.10 gears instead of a converter or would that be pushing my luck?
still have the gears just sitting in the closet.
would be nice to be running high 11s next summer.
With the lower stall on the stock T/C, you will launch at lower rpms = lower amt of torque at launch = less stress. Torque is what will break the shaft. Yes, 4.10's will get you up and going that much quicker, as long as 1)you have the traction, and 2) you don't mind the hwy RPM levels.
Other than the above mentioned fluid change, I'm running a stock tranny. So far so good. I had a 3000 stall converter in there for about a month but wasn't happy with the feel. I know some people love them but it just wasn't for me. BTW, 1 month old T/C for sale, best offer!
