gear ratios
Old 10-18-2008, 07:30 PM
steverino
steverino's Avatar
Default gear ratios
I have an '08 GT with automatic. Does anybody know the gear ratios of the automatic transmission? It seems to rev kinda high when I leave the gear shift in 3rd, so I'm thinking 3rd must not be 1.00:1. Am I correct in thinking the rear end is a 3.31:1 ratio? Thank you.
steverino is offline
Old 10-18-2008, 08:30 PM
Argonaut
Argonaut's Avatar
Check out this sticky: https://mustangforums.com/forum/4-6l-v8-technical-discussions/446207-gears-wheels-tires-revs-rpms-and-mphs.html
Different cars have different rear ratios, yours should say on the sticker inside the drivers side door frame or on the rear differential cover.
Argonaut is offline
Old 10-18-2008, 08:40 PM
mustang2000GT
mustang2000GT's Avatar
The axle code is written on the inside of the driver's door on the white label, it
will be a two-digit code of two letters.
mustang2000GT is offline
Old 10-18-2008, 09:24 PM
Nuke
Nuke's Avatar
Here's the ratios for the 5R55S Auto in the S197's:
1st/2nd/3rd/4th/5th (OD) - 3.22/2.29/1.54/1.00/0.71
Nuke is offline
Old 10-19-2008, 01:33 PM
stealth_GT
stealth_GT's Avatar
you are correct it is 3.31 but I think they should have put 3.73s or made 3.90s as an option.They might as well put 2.81 gears because that's what they feel like lol.
stealth_GT is offline
Old 10-19-2008, 05:29 PM
Texotic
Texotic's Avatar
hey nuke, do you know the ratios for the manual?
Texotic is offline
Old 10-19-2008, 07:59 PM
Argonaut
Argonaut's Avatar
Here is what it says in Wikipedia:
TR-3650 used in the 2001-present Ford Mustang GT
1st: 3.380:1
2nd: 2.000:1
3rd: 1.320:1
4th: 1.000:1
5th: 0.620:1
http://en.wikipedia.org/wiki/Tremec_...0_transmission
Argonaut is offline
Old 10-19-2008, 08:44 PM
Nuke
Nuke's Avatar
1st: 3.380:1
2nd: 2.000:1
3rd: 1.320:1
4th: 1.000:1
5th: 0.620:1
The OP was looking for the automatic values.
My source says 0.675 for 5th on the Tremec 3650 manual. Don't know which one is correct.
Nuke is offline
Old 10-19-2008, 09:59 PM
sailing220
sailing220's Avatar
And some other guy asked about manuals...
sailing220 is offline
Old 10-19-2008, 10:54 PM
Texotic
Texotic's Avatar
yeah, i was asking about the manuals. sorry for the confusion.
Texotic is offline
Quick Reply: gear ratios
