gear ratios
gear ratios
I have an '08 GT with automatic. Does anybody know the gear ratios of the automatic transmission? It seems to rev kinda high when I leave the gear shift in 3rd, so I'm thinking 3rd must not be 1.00:1. Am I correct in thinking the rear end is a 3.31:1 ratio? Thank you.
Check out this sticky: https://mustangforums.com/forum/4-6l-v8-technical-discussions/446207-gears-wheels-tires-revs-rpms-and-mphs.html
Different cars have different rear ratios, yours should say on the sticker inside the drivers side door frame or on the rear differential cover.
Here is what it says in Wikipedia:
TR-3650 used in the 2001-present Ford Mustang GT
1st: 3.380:1
2nd: 2.000:1
3rd: 1.320:1
4th: 1.000:1
5th: 0.620:1
http://en.wikipedia.org/wiki/Tremec_...0_transmission
1st: 3.380:1
2nd: 2.000:1
3rd: 1.320:1
4th: 1.000:1
5th: 0.620:1
1st: 3.380:1
2nd: 2.000:1
3rd: 1.320:1
4th: 1.000:1
5th: 0.620:1
1st: 3.380:1
2nd: 2.000:1
3rd: 1.320:1
4th: 1.000:1
5th: 0.620:1
My source says 0.675 for 5th on the Tremec 3650 manual. Don't know which one is correct.
