Gasket Problems 2007 4.6
i think this section is fine,
i am glad to hear you got her back and shes all fine. I truly do hope all is well with her and that the stealership didnt hurt her at all. as per causes??? bad gasket, crap assembly? dont know i dont think anyone else will know either but good luck.
there are two, one on either side. both on the front aspect of the valve covers both leading to the intake, one goes into the intake before and one after the throttle body. there are hard lines leading to the intake.
check them for oil, il bet dollars to donuts the drivers side has oil in it and the passenger side little to none.
look up oil seperator in the xearch funtion. i went with the el cheapo one total cost like 40bucks and got all the parts at home depot.
TfcCDR
09-14-2015 12:08 PM
