My car has a new trick
Old 12-16-2008, 07:47 PM
wilkinda
2010 Section Moderator
wilkinda's Avatar
Unhappy My car has a new trick
So my car has been playing this new trick on me for the past 2 days. It will run fine..then start idling weird while waiting at light or pulling into a parking lot and no matter how much I try to give it gas..it stalls. I wait a few minutes and it starts and runs just dandy. Pull up to a light or parking lot and the idle starts going wacky again. It doesn't do it all the time at intersections or parking lights. Its totally intermittent.
In addition I hear this weird electronic sounding buzzing noise coming from under the hood. I removed the fuse box cover and that is where it was coming from. It was fuse #29 which is for the rear defroster.... I pulled the fuse and bought a new one...installed it and the same result..buzzing noise. It also is intermittent and does not do it all the time..
Any suggestions?? Is this the "battery phenom" that I have read about before??
wilkinda is offline
Old 12-16-2008, 07:51 PM
2007VistaBlueGT
2007VistaBlueGT's Avatar
The obvious answer is take it to dealer if it's still under warranty...the other obvious answer is um...eh...well if it was obvious i'ld tell you.
Buzzing is never good, sounds like a short. Did you check all the other fuses? The rear defroster pulls a ton of voltage basically it shorts the filaments across the back window that's how it heats up.
2007VistaBlueGT is offline
Old 12-16-2008, 07:57 PM
wilkinda
wilkinda's Avatar
It is still under warranty..the issue is getting the time to drop it off and wait for it.
no other fuses seem to have an issue. Funny thing is the defroster is not even on!! I checked it with my fluke VM and no voltage detected but the fuse is humming away
wilkinda is offline
Old 12-17-2008, 11:11 AM
J2L06GT
J2L06GT's Avatar
Are you sure it's the fuse making the noise,
there are some small relays in the fuse box
that would more likely make a buzzing sound.
Try unplugging and reinstalling them, might have
dirty connecton on one.
J2L06GT is offline
Old 12-17-2008, 01:01 PM
Simon1
Simon1's Avatar
I wouldn't even mess with it if it's under warrunty.
Simon1 is offline
Old 12-17-2008, 05:13 PM
travelers
travelers's Avatar
Sounds like a dirty MAF.
travelers is offline
Old 12-17-2008, 07:06 PM
wilkinda
wilkinda's Avatar
I misspoke.. It is a relay, #29. it was buzzzing. i pulled it out and cleaned the contacts and re-installed.. same result. i bought a new one and installed it..same result. Fo now it is just out....it's for the rear defroster
wilkinda is offline
Old 12-17-2008, 07:08 PM
wilkinda
wilkinda's Avatar
the Ford dealer just cleaned that whole system a few months back and the car is a DD but since I am on vacation it is hardly driven lately
wilkinda is offline
Old 12-18-2008, 01:10 AM
FA_SHO
FA_SHO's Avatar
good luck with this man. i have a few issues with my 07. ford dealers usually take care of this stuff though
FA_SHO is offline
djbigskrilla
09-20-2022 01:04 AM
Mobiusone stang
08-24-2015 04:08 PM
MXBT187
08-20-2015 02:36 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
Quick Reply: My car has a new trick
