Am I crazy? Too much gear?
so I got one vote for 4.56 and 2 for 4.10. Thanks for the recomend on tires as well.
These were the MTs I was looking at
3785R P305/35R18 27X12.50R18 31 R2 10.0-12.0 11 12.5 11.5 26.4 83
http://www.mickeythompsontires.com/s...StreetRadialII
Earl
I'd say 4.10s or 4.30s, I run 4.10s with a V2-SQ and MT 265/40/18 DR its a nice set up IMO, my effective gear is around 4.22 (tires are 26.4") however if you go with a a bit taller tire then the 4.30s would work well IMO. the tire you reference is the same 26.4 as mine, you have the wheel width, get the 345/35 @ 27.5 with either gear set you'll be very well off IMO.
the centris love RPM so the faster you get up there the better for power. get yourself a good shifter as well cause you'll be rowing faster with the steeper gear
I had BFG 265/40s for one season and got 1.73-1.8 typically
this season I used the MTs the BFGs were discontinued and the MTs were new this past year, I've pulled 1.68-1.69s consistently with them
IMO the M&Hs are better, but they were not around when I needed tires. A friend has them and has pulled low 1.5s IIRC (but he has 600+rwhp)
i want 430s and am hoping to install them before the next track day in the spring. for me being NA and allways will be but want cams ect 430 seems right to me. the top of 4th will bring me to the trap.. vrs 410s id only be middle of the high end.
add a vote for 430s
add a vote for 430s
well,
according to my math 430s with a good tire is capable of decent traction.
if you are gonna run **** all serasons with all bolt ons you need tires. if you run **** ties you got **** traction.
is 1st useless. no not according to my math, yes it will be quick but it will do its job. yes it will reduce gearing but IMO the best move as far as gears go. I am awaiting there install
as i figure it a NA stick will be doin about 112 mph in the traps on stock tire diameter before needing less then a 430 to hit less the the 430s at the traps in the top of 4th.
why go 410s if your gonna stay na then???
so looks like the common thought now is, 4.30s can handle if I stay NA, but if I drop a FI system on the 4.10s will do me better for traction and getting a longer pull I would need in the gears to finish off the 1/4
