Low Idle after battery swap?
Old 02-17-2009, 07:15 AM
bzimmer260
bzimmer260's Avatar
Default Low Idle after battery swap?
I have a 05 Mustang GT and the battery died yesterday. It had been pulling low for the last couple of weeks so it wasnt a surprise. I put in a new battery and it fired right up...but it seems to not go through its usual warm up sequence. RPM also come way down, almost to 0 when driving and coming to a stop...once off idle it drives fine but when coming to a stop the tach almost bottoms out. Do I need to unplug the battery in order to reset the computer? Am I dealing with a bigger problem?
bzimmer260 is offline
Old 02-17-2009, 10:38 AM
sailing220
sailing220's Avatar
Do you have a custom tune? Try reloading it.
If not, it sounds like a throttle body or MAF issue. Check the connections for the TB and if it still doesn't go away, try getting some MAF/Throttle body cleaner and clean both of them.
I don't think that "pulling low" as you put it (I'm assuming this means not as hard) is a symptom of a dying battery, but if that went away after the new battery, who am I to argue? Ha..
sailing220 is offline
Old 02-17-2009, 04:26 PM
ski
ski's Avatar
It may also be caused by the ECM re-learning the idle strategy, which is wiped out when replacing the battery. There's a procedure in the owner's manual for helping the ECM to do this after installing a new battery.
ski is offline
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
dalefrancis88
09-11-2015 07:15 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
Art161
09-09-2015 10:33 AM
Mobiusone stang
09-07-2015 08:46 PM
Quick Reply: Low Idle after battery swap?
