Please help ASAP with Pulleys URGENT
Hey Guys
I am a newbie to the forum this is actually my first post. I have a major problem i was installing underdrive pullies and somehow i managed when i installed the new pulley i used the harmonic balancer install tool i got the adapter for the tool stuck in the crank and i cannot get it out. Can someone please help with this i hope i did not damage the crank i am such an idiot
Thanks for your help
Frank
Frank
i cant turn it as i cant get a socket around it, it is just round kinda hard to explain actually but if you look at this link toward the bottome of the page here is the exact tool i used i got the long bolt out but the adapter is stuck in the crank
http://www.cherod.com/mustang/HowTo/Pulleys.htm
so one of the adapters that i circled is
still in the crank...
hopefully someone will have a good solution
for you, i'm not sure how i would get it out
except for some sort of easy out. i'm sure
there's a simpler way
yes exactly it is one of the adapters that you have circled
