proplem with automatic transmission !!
hi all
i have mustang 2007 GT atumatic transmission , the proplem when i put it in " D " draive and move the car normally and bush the brak hard to stop the car , the car be stopped but when i remove my lage from the break the car be almost stop and it's still in " D " , so i WOT the fuel and it push it the gear hardlly and it's move , any one know what the proplem
QTR, I don't think I have an answer for you right now. I just want to make sure your question is clear. Are you saying that after a hard brake the car won't accelerate again when you step on the gas again? Does the problem go away after you cycle back from neutral back to drive?
yes see the video
http://www.youtube.com/watch?v=Ggh1hCZoiwo
you're using a translator aren't you? lol..
hmm..maybe it's the torque converter?? I had the same problem with my 93 rx-7 and the torque converter was messed up, sometimes it would catch on the gear, sometimes it won't.. it did something similar to your car.
I had the same problem with my 05 GT auto after a panic brake the other day. When everyone settled down and I went to acclerate, the car wouldn't move. After about 30 seconds there was a big "bang" through the drive line as the car went back into gear. Since then everything has been fine. Its like under a panic brake, the transmission automatically goes into neutral, then has to hunt to find a gear again.
