2005 to present Mustang GTs- does anyone know if they came equipped with 28 or 31 splines? Also, does the car need to be reprogrammed if you swap gears from stock to 3:73s?
Great, thanks for the info.. Now, has anyone accomplished a gear change on the newer Mustangs 2005- present? If so, is there any online tech info I can use for the job?
31 splines for the 8.8 and 28 splines for the 7.5.
