ordering my gears !!
alright, i'm gonna order my gears tonight, and after some pretty intense researching, i only have a few questions unanswered
1 - ordering them from brenspeed, im having them installed by a 30 year ex ford tech, should I go with the ford racing or motive ? I only ask this because i've been told motive was made better, but also have been told motive will give the dreaded gear whine
2 - Do I need the ARP Ring Gear Bolt for $28.49 ?
3 - Do I need the Royal Purple Max gear oil, and if so, how many quarts
4 - He told me to get the master shim kit, but my car is an 06 with 33K , only seen salt a handful of times, never driven in the snow.
5 - 3.73 or 3.90 if i plan on a kenne bell wayyyy down the road when i can afford it
thanks !!! cant wait to order!
I just ordered my 4.10 gears from Brenspeed. You do not want the Motive gears. Get the FRPP 4.10a gears only. I got the master install kit too. Its only few dollars more than the shim kit. My car has 28K. I would rather be safe than sorry and went with the master install kit. Also got one bottle of the RP gear oil. I did not get the ARP bolts. I am getting a axle girdle installed which came with new bolts. Typically if you stay NA go with 4.10s and for FI go with 3.73.
musnicki
09-23-2015 07:11 AM
09-03-2015 07:14 PM
