lc-1 windeband question
i got a lc-1 wideband with a g2 afr gauge
Has anyone installed this ? i need some help here. i wired everything up right, but i did not use the led light because it was missing, i'll buy one tomorrow. but anyway.
when i start the car the niddle goes all the way to the end and comes back, but it does not start working after that.
here is how i wired
the brown cable from the gauge, i used the constant 12v source from the lighter,i
the red wires to switch on 12v from the passenger kick pannel. with a 30amp fuse
grounded all the cables to a good metal source
white cable from the gauge to the light switch
blue white and bare cable from the lc1 to ground
lc1 brown cable to gauges green cable
lc1 black cable to the switch then switch to the ground. (i need to put the led there)
the oxygen sensor is on the drivers side. everything is plugged in. dunno what to do. anyone has a clue?
here is how i wired
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
