EXHAUST emitting moisture in the A.M.
Old 07-18-2009, 10:57 PM
jreask
jreask's Avatar
Default EXHAUST emitting moisture in the A.M.
I noticed this AM that there is moisture from my exhaust right at start up. Not just a little. It is spitting , almost like raining out the tail pipes. I guess it could be normal?
Also, I have been reading some rumors that Brenspeed's tunes are dangerously close to being too lean. Can someone comment on that? I don't really understand the whole lean/rich thing.
Thanks in advance.
JR
jreask is offline
Old 07-18-2009, 11:06 PM
Nuke
Nuke's Avatar
The moisture from the exhaust, especially after sitting overnight, is normal.
I wouldn't worry about running lean unless you're throwing a CEL.
Nuke is offline
Old 07-18-2009, 11:09 PM
GAP
GAP's Avatar
You can accumulate a lot of condensation in the exhaust. It's normal like said above. My brenspeed tune was rich. Mine was 12.7ish so I leaned it out some.
GAP is offline
Old 07-19-2009, 09:00 PM
2007VistaBlueGT
2007VistaBlueGT's Avatar
Moisture is good, It's a byproduct of complete burn when water comes out of your tail pipe it means your combustion is very complete, the reason fo excess in the morning is the cold exhaust pipes
2007VistaBlueGT is offline
Old 07-21-2009, 09:31 AM
VistaGT
VistaGT's Avatar
Brenspeed does run a bit leaner than other tuners do but it's in no way dangerously lean or something you should worry about. I must be the king of research on this haha. I was worried about the same thing-being too lean. I've talked to as many tuners of S197s that I could find. Actually it's more about timing and detonation than it is about the A/F Ratio.
Ex: As long as there's low timing and no detonation, you could be fine driving around in the 14s. As a rule of thumb 13.3 is about as lean as you want for power. After that it loses power and isn't ideal but not deadly.
This is based off the S197. I've talked to everyone I could find. You name it I've probably had a LONG chat with them lol.
Also, like everyone else said-don't worry about the moisture it's normal.
VistaGT is offline
4cylinderplus2
10-09-2020 07:45 PM
Dokilar
15
10-16-2015 08:13 PM
09-30-2015 12:39 PM
DtRockstar1
Mustang Videos
09-27-2015 07:46 PM
09-24-2015 09:18 PM
Quick Reply: EXHAUST emitting moisture in the A.M.
