p2104 and p2111 codes...?!?!?!?!
i just got my car back from Ford after having my diff rebuilt for something they messed up on last time but after i got it back the guy told me to take it easy for a thousand miles. i did so and after i got to 1k i put the pedal to the medal and after i got off the gas my car started bogging and the wrench and the engine light came up and the gas cut off completly ... and i got the p2104 and p2111 codes.. i took it to my friend thats a mechanic and he told me to get a new actuator for my throttle body..? has anyone had this problem before? your help is appreciates thanks in advance!
2104 means the TAC (throttle actuator control)TA system is in failure mode which usually is in conjunction with another code.
2111: The powertrain control module (PCM) fault status indicates the throttle plate is at a greater angle then commanded.
Possible causes:
• Binding throttle body, stuck open
• TAC motor circuits are cross wired
• TAC motor harness circuits are shorted together
• Damaged PCM
Possible causes:
• Damaged PCM
egmotorsports
05-29-2011 09:20 PM
