gearing/supercharged??
I am sure I am getting the Vortech V3 non-intercooled very very soon.
I have 4.10s right now. Should I re-install the 3.31s or be a complete wuss ball and get 3.27s??
I WANT TRACTION!
I WANT TRACTION!
well I have 3.31s and I'm putting 420 too the back wheels. With the stock tires I would spin all the way threw 2nd gear. Now with 315/35/20s in the back I can still spin first if i step on it but not 2nd aassss bad. I dont know how anyone drives with 410s and a supercharger.. just my 2 cents
I have owned 6 total Mustangs, 3 SN95 and 3 S197s. All of which have 4.10 gears and centri blowers. Buy a good suspension and better tires and if you can learn how to launch the car you'll have a ton more fun. Centri blowers build boost with load/rpm, too numerically low of a gear and you can feel a slight lag until you build back up the revs. Go with 4.10's with a stick, and 3.73 or 3.90's with an auto. Thsi will keep you in the power band of the blower and make for an all around better drive. If you are concerned about traction, buy a Torsen diff and wide tires.
Even my girlfriend can drive my new S197 TWIN TURBO GT easily with 4.10s and 12psi of boost making well over 500 wheel and I have the weight in that car down to 3150lbs wet.
just had my relocation brackets welded and put on some HD Boxed sub frame connectors. Feels like a whole new car, actually get some traction now, and keep in mind.... i'm running Supercars and its like 27 degrees out
Good god where do you people get all this money !!! I can't even afford a S/C on 1 S197 !!! lol
