Hot Rods are in!
#31
Do you guys know the fix for the flashing O/D light problem when coasting slow (~20mph)?
I know what the fix is in the tune thanks to someone on another forum and so does Brenspeed now (thanks to me) and I've been curious about an All Out tune but I don't want that flashing O/D light to come back.
#32
How did you hold the chains in place and was it as simple as just removing the valve covers, unbolting the cam bearing caps and ubolting the cams? I saw a post like that a while ago but thought that had to be to simple.
Can't wait to see the dyno numbers. Do you have baseline numbers on your specific car?
#33
I basically used the hose method and had a friend back up that method by constantly keeping pressure by holding the cam gear while I swapped the cam. Yeah you are correct with the rest basically. I turned everything over before I started each side so it looked like the least amount of pressure was on the cam.
I do not have a baseline dyno but I am excited to see what it puts down and also what Chris can extract from its current state.
#34
Well no go on the dyno tune. I went there yesterday and Chris strapped her down and started to do some adjustments. He came up and said I have a huge vacuum leak. While it was on the dyno still they checked the back of the intake and sure enough those steeda delete plugs did not do there job. This is not the first issue they have seen. So they told me how to fix them and I left there and went to work and pulled the intake manifold back off. I verified they were leaking and fixed the issue and did some logs of short term fuel trim and the issue is now fixed. I will contacting steeda this week and giving them hell about there ****ty product. I guess you cant expect much for 70 bucks. I am going back to get dyno tuned on wednesday so we shall see.
#35
Take a look at the link I posted earlier in this thread.
Mine are due Tuesday. I called Steeda already about this, and they recommended the small amount of sealant.
I'm still waiting on Chris to email the new tune - I guess you're the reason it didn't come on Saturday as promised
#36
Glad you got it worked out. Loving the sound of that cam.
patrick
#37
Thanks man!
#38
#40
Well I just got back from tillman. I was a little bummed about the dyno numbers but I dont have a baseline so Its kinda hard to compare. My car dynoed 306whp and 313wtq. Im sure with some long tubes or at least high flow cats that would help alot.
